Login
YoutubeInstagramRSSGithubPatreonPrivacy
Fixt â€ĸ Š 2025
Updated: Jan 20, 2025—5 min read
Ultimate ESPHome DIY Smart Sensor
PrerequisitesfixtSE DIY Sensor CaseRemixesClip for TopMMwave Multi Sensor fixtSE LD2450How to wire it upESPHome FirmwareYAML Files
Easiest way to Control your Smart Home with AI: Ollama + Home AssistantEasiest way to Control your Smart Home with AI: Ollama + Home Assistant
Sensor
mmWave Sensor
Side a
Side b
Inside
ESP32
HLK-LD2450 Presence Sensor
BH1750 Light Sensor
AHT20 BMP280 Temperature Humidity and Pressure Sensor
BH1750 Sensor
  • BH1750 Light Sensor
    • Amazon: (3 pack)(6 pack)
    • Aliexpress: (BH1750)
AHT20_BMP28 Sensor
  • AHT20 BMP280 Temperature Humidity and Pressure Sensor
    • Amazon: (6 pack) (2 pack)
    • Aliexpress: (AHT20 BMP280)
Dupont cable
  • Dupont Cable
    • Amazon: (Dupont Cable 120 PCS Assorted)
    • Aliexpress: (Dupont Cable Male to Male and Male to Female)
Termoretractil Heat shrink tube
  • Termoretractil Heat shrink tube
    • Amazon: (Heat Shrink Tube)
    • Aliexpress: (Heat Shrink Tube)
You can get it on:
Or order it from:
Save $5 on your first order using our link: https://pcbway.com/g/lHR6if
Remixes
Clip for Top
Clip
checkleylane made a clip to held the top of the original case
You can get it on:
Reimagined Case
F-Square made a new case for this project, with a lots of improvements:
  • Rearranged the sensors inside the case (now the case can look up, instead of down).
  • Added M3 Screws, so the body can be held in place easily.
You can get it on:
How to wire it up
Wire Up
ESP32 BoardBH1750AHT20 BMP280
3v3VCCVDD
GNDGNDGND
D22SCLSCL
D21SDASDA
ESPHome Firmware
Updated firmware to ESPHome 2024.12.4
Added OTA support
Not supported browser detected
Try a different browser!
The only difference between the two firmwares is the Bluetooth Proxy. If you don't need it, you can use the firmware without it.
You can find the documentation here
Bluetooth proxy could be an expensive task, if you experience any issues, try the firmware without it.
FirmwareSensor Name
With Bluetooth Proxyuesp-sensor
Without Bluetooth Proxyuesp-sensor-no
YAML Files
v1.2.0:
Added OTA support (deactivated by default)
Changed bmp280 to bmp280_i2c
Shop Content
YAML
TinkererFree
Member Banner
Available in our Store! Or, join the Tinkerer or Automation Hero tier to access our latest Shop Content for FREE!
  • Your support is invaluable in allowing us to continue creating the tutorials you like 😁🏠🎉
  • Click on the Patreon button below to become a member, and then log in with your Patreon Account on our website.
Sensor
Sensor
